[SOLVED] Help needed migrating node-red to docker
Hello. I would like to migrate my node-red to a docker container. I have installed some nodes using npm and I would like to move them too into the container. Could someone please help me?
This may help you: Running under Docker : Node-RED
Also: Docker - FlexDash - just ignore the flexdash specific stuff...
Note that containers should be considered immutable, if you have variable data, store it in a volume as the links from @tve show.
Are you sure you want to do that? Only do it if you have a good reason, as it does cause complications.
@bakman2 yes I know, I've already created a folder bound to the dockerized node-red.
@Colin Which kind of complications? I don't use node-red for lot of stuff, I made a pair of flows that "translate" tuya messages in MQTT for a better integration of some of my devices in Home Assistant.
I've already moved 99% of my flows on the dockerized node-red but I need find a way to bring back the 2FA. I shared my work here but I don't know how install passport-google-oauth20. in my external volume.
I've accessed the node-red bash and launched
npm install passport-google-oauth20
but i don't see new modules added in my /home/me/node-red-docker/ folder. Could you help me please?
Hello. I would like to migrate my node-red to a docker container. I have installed some nodes using npm and I would like to move them too into ... I thought I'd try nodered docker container for once as I used (really just used) some other Docker containers recently. Getting the Node-Red v1. This container can be extended to add the required prerequisites for your projects. For example to add the required libraries for the node -red -contrib-machine- ... A node is **an instance of the Docker engine participating 192.168.l.254 in the swarm . You can also think of this as a Docker node. You can run one or more nodes on a single physical computer or cloud server, but production swarm deployments typically include Docker nodes distributed across multiple physical and cloud machines.
The sort you are having now, apparently.
You're absolutely right :slight_smile:
Solved! It was a stupid, stupid detail. I've added in package.js the line "passport-google-oauth20": "~2.0.0" , now I'm able again to log in withmy google ccredentials :slight_smile:
Thanks to you all!
