[SUGGESTION] a node "ring that brings them all together 🧙"
I am often embarrassed with the quantity of thread that I have to pull to unite several knots between them.
Therefore, I suggest a knot that lets all kinds of messages pass. I know that we can do it with a Function node which return msg, but it is more practical to have it compact and without any parameters.
Hi @SuperNinja
this has come up a few times. We have always pushed back because its so easy to create such a node straight from the default palette.
My usual solution is a Change node with its default rule removed. And you can hide the label from the appearance tab of the editor.
What about this?
I note, thank you
I will be satisfied with this tip :wink:
Just checked my flows, to see if I can beautify them with the hints.
Found that I'm using the link nodes to get rid of too many lines.
Or sometimes I send the messages to the MQTT broker, if I think this is general useful information in the data tree and subscribed at various other places.
But I see your point.
That is really 'one node that rules them all'... Thanks for sharing. I have a few places for that...
I cant tell if you are joking or not? :smiley:
You know you can just use a build in node e.g. a change node (remove its entry) or a function node with return msg in it?
well I was having fun... with the LoTR reference...
However, I will admit I didn't know about applying a change node in this manner. thanks for the tip.
That said... I like the NOOP node... upon looking at it I will know automatically that there is nothing hidden inside of it....
