Disable wires/connections between nodes
I would also like to bring back into focus a feature that was discussed in a 2022 forum thread: namely the ability to enable or disable a wire. In that discussion, it was mentioned that such a feature would require changes to the flow file format, which is why it was not pursued at the time. However, given its usefulness for debugging and maintaining complex flows, I would like to raise this request again and highlight its continued relevance.
|100%x100%
Yeah, the best I could manage was to put a junction node in the middle and disable that. Not ideal, but a workaround nonetheless.
Honestly that was going to be my recommendation, to put a disable node of sorts inbetween. I wonder - would be creating a passthrough node that could be disabled be a "good enough" solution in this case?
That's indeed a workaround, thank you! And with cmd + delete the connection remains intact. But it's extra clicks and "fiddling"
That is exactly what a Junction node is, no need to create a new node type.
Hi @rko
I do hear what you are saying, and kind of feel your pain.
But I feel there is an easier solution.
So let's break down what you want to do.
You have two nodes connected with a wire and you want to disable it.
Now, there are two reasons I see for wanting to do this.
1 - you want to work on the node sending the message.
(or)
2 - you are wanting to isolate the receiving node as it will/could have more than 1 input wire.
So, my solution
For option 1:
Disable the node receiving the message/s.
(That is the easiest.)
For option 2:
The second node has multiple inputs and - I'm guessing you want to isolate other wires going to it.
So basically you disable the other nodes that are sending the messages.
Would either of those work?
I agree, I could just see the counterpoint that not having something named and clear would make managing complex flows annoying to some specific types of developers/users.
so something like this:
Screen Recording 2025-12-04 at 11.27.32
select existing wire, insert junction, disable junction - done
for extra bonus points, add a menu options "disable wire" that does those three steps in one! :wink:
EDIT: I'm not saying this is the perfect solution, especially as extra and unnecessary junction nodes are created, but it's a solution that works today.
Omg .. I did not know that - so sorry for bothering you guys!
Edit: Somehow, I cannot mark this post as solved.
There is also the fan node.
Sometimes handy to use.
node-red-contrib-fan
Possibly because it is a core development request.
It can't be SOLVED.
:person_shrugging:
Feature request can't be solved? :upside_down_face:
Well, they are a request.
Not a Problem.....
That's my perspective on how it works.
(Though I know I have been wrong before) :wink:
It should really be a Problem is Unproblemitised, so that a Feature Request becomes Unrequestirised.
And a general Topic is Untopicised - far simpler than these two different words idiomie!
I've got 99 problems but this thread certainly isn't one as it's a request.
And if we keep replying, it will never be shut!
Screenshot 2025-12-04 at 16.22.46
"solving" now enabled
(it just wasn't set on this sub-category)
Thank you, I can sleep again :rofl:
Would be very useful to disable a connection rather than having to delete it, and users have wanted it for years. Ideally it’d just display with a dashed line as normal.
I didn’t understand why this Feature Request was marked solved…? It ain’t possible yet so it ain’t solved
The original wasn't solved - it was closed by timing out as no further discussion happened (or was needed, as Nick had explained why it was not possible without a major update to the flow file format ).
