Node names keep disappearing when edit dialog is closed?
I seem to have encountered a strange issue with a node-RED node I have been working on. It seems to be an intermittent error. But I am wondering if it is something that has been picked up on before. I have been working on a node with a configuration dialog.
Sometimes after opening and closing the configuration dialog, then closing the parent edit dialog the node name disappears, see next image:
c9883693-9921-49c0-95f9-92eb10c9aec6
There is a warning in the error console, but no errors reported.
I am trying to determine if this is an issue specific to the node, something to do with browser based garbage collection, or a Node-RED related issue?
Any node can be configured to hide its label - its an option on the appearance tab in the edit dialog. Under the covers, it sets a boolean property on the node called l. One possible explanation is that your custom node is setting this property itself.
Thanks for the info, I was reading this article
it could be the editor, I think the issue occurs when there is relatively heavy node-RED usage. For example lots of different nodes having the editor. opened and closed.
